Hello guys,
is there a way to determine if order was created with repay flag enabled ? see example on the screenshot:
Its easy when order created as normal, without loan or repay. Also it
s clear when the order was created with loan flag, because in account i can find borrowed amount. But when limit order was created with loan flag i don`t see any sign of that.
What i basically need is to get 100% accurate information about an order.
Can you suggest me something ?
Regards,
Ruslan
