help Update Ads /sapi/v1/c2c/ads/update
I am using the corresponding endpoint and still getting this error:
Status Code: 401
Response Body: {‘code’: -1002, ‘msg’: ‘You are not authorized to execute this request.’}
I’m attaching part of the code I’m using to execute it. What I want to do is edit the price. I’m not sure what else to do at this point.
import hashlib
import hmac
import requests
import json
from urllib.parse import urlencode
Credenciales de Binance
API_KEY = ‘’
SECRET_KEY = ‘’
BASE_URL = ‘https://api.binance.com
Endpoint y parámetros
endpoint = ‘/sapi/v1/c2c/ads/update’
url = BASE_URL + endpoint
Cuerpo de la solicitud JSON
request_body = {
“advNo”: “12619026838743379968”,
“advStatus”: 1,
“asset”: “usdt”,
“fiatUnit”: “clp”,
“price”: 0.92,
“tradeMethods”: [
“identifier”: “Zinli”,
“payType”: “Zinli”
“tradeType”: “0”,
“updateMode”: “selective”
Convertir el cuerpo de la solicitud a cadena JSON
request_body_json = json.dumps(request_body, separators=(‘,’, ‘:’))
Crear la cadena de consulta ordenada para la firma HMAC
query_string = urlencode(sorted(request_body.items()))
Generar la firma HMAC SHA256
signature = hmac.new(SECRET_KEY.encode(‘utf-8’), query_string.encode(‘utf-8’), hashlib.sha256).hexdigest()
Headers requeridos con la API Key y la firma
headers = {
‘X-MBX-APIKEY’: API_KEY,
‘Content-Type’: ‘application/json’,
Agregar la firma al header
headers[‘Signature’] = signature
# Realizar la solicitud POST con requests
response = requests.post(url, headers=headers, data=request_body_json)
# Imprimir la respuesta
print("Status Code:", response.status_code)
print("Response Body:", response.json())
except Exception as e:
print(“Error occurred:”, e)
The endpoint /sapi/v1/c2c/ads/update is not included in the API P2P endpoints documentation. If you have any questions about P2P/C2C merchant endpoints, please kindly contact Customer Support team.
thanks i have instruccion but i can solve his problem
i have this but i cant used, im a merchant
pudiste resolver, ando en el mismo desarrollo
YES I CAN
Como pudiste resolverlo amigo, ando en el mismo dilema. pudieras compartir la información?
