O código está completo
Após recebe a mensagem do telegram
Eu preciso abrir uma ordem de trailingstop 10% e colocar um stoploss de 20%
Mas a ordem executa aparece o breakeven que se comporta de forma diferente e o stop não fecha minha posição
The code is complete
After receiving the telegram message
I need to open a 10% trailingstop order and place a 20% stoploss
But the order is executed and the breakeven appears, which behaves differently and the stop does not close my position
from telegram.ext import Updater, MessageHandler, Filters
from binance.helpers import round_step_size
import ccxt
import re
def extract_trade_info(message_text):
# Usando expressão regular para extrair o símbolo
match = re.search(r’\s+(\S+)', message_text)
if match:
symbol = match.group(1)
else:
print(“Não foi possível extrair o símbolo.”)
return None
action_line = [line for line in message_text.split('\n') if '🔴' in line or '🟢' in line]
if not action_line:
print("Não foi possível encontrar a linha de ação.")
return None
action = action_line[0].split()[1].upper()
target_price = float(re.search(r'🎯\s+([\d.]+)', message_text).group(1))
return symbol, action, target_price
def get_tick_size(symbol, client):
info = client.futures_exchange_info()
for item in info[‘symbols’]:
if item[‘symbol’] == symbol:
for f in item[‘filters’]:
if f[‘filterType’] == ‘PRICE_FILTER’:
return float(f[‘tickSize’])
def get_rounded_price(symbol, price, client):
tick_size = get_tick_size(symbol, client)
return round_step_size(price, tick_size)
def calculate_stop_loss_and_gain(current_price, stop_loss_percentage, take_profit_percentage):
stop_loss_price = current_price * (1 - stop_loss_percentage / 100)
take_profit_price = current_price * (1 + take_profit_percentage / 100)
return stop_loss_price, take_profit_price
def message_handler(update, context):
print(“Handling message:”, update.effective_message.text)
chat_id = update.effective_chat.id
message_text = update.effective_message.text
print(f"Nova mensagem no grupo {chat_id}: {message_text}")
# Criar instância do cliente Binance
binance_api_key = 'API'
binance_api_secret = 'SECRET'
client = Client(binance_api_key, binance_api_secret)
# Inicializa current_price com 0
current_price = 0
# Tentar extrair informações
trade_info = extract_trade_info(message_text)
if trade_info:
print(f"Informações extraídas: {trade_info}")
# Desempacota as informações da ordem
symbol = trade_info[0]
action = trade_info[1]
target_price = trade_info[2]
# Adapte os valores conforme necessário
amount = 0.1 # Valor desejado
leverage = 30 # Alavancagem desejada
stop_loss_percentage = 0.02 # Porcentagem para o stop loss
take_profit_percentage = 0.02 # Porcentagem para o take profit (stop gain)
activate_price_percentage = 1.5 # Substitua pelo valor desejado
activate_price = current_price * (1 + activate_price_percentage / 100)
# Conecta-se à API da Binance usando a ccxt para o mercado futuro
exchange = ccxt.binance({
'apiKey': binance_api_key,
'secret': binance_api_secret,
'future': {
'enableRateLimit': True,
'defaultType': 'future',
# Adiciona 'USDT' ao símbolo se não estiver presente
if 'USDT' not in symbol:
symbol_with_usdt = f"{symbol}USDT"
else:
symbol_with_usdt = symbol
ticker = exchange.fetch_ticker(symbol_with_usdt)
current_price = ticker['ask'] # last
current_price = get_rounded_price(symbol_with_usdt, current_price, client)
stop_loss_price, take_profit_price = calculate_stop_loss_and_gain(current_price, stop_loss_percentage, take_profit_percentage)
# Inicialize a variável stop_loss_order
stop_loss_order = None
# Obtenha o preço médio atual
price = float(client.get_avg_price(symbol=symbol)['price'])
# Obtenha o tick_size usando a função get_tick_size
# Defina a porcentagem desejada para o stop loss
stop_loss_percent = 5 / 20
# Calcule o novo stopPrice
stopPrice = round_step_size(price - (price * (stop_loss_percent / 100)), tick_size)
# Configurações específicas do mercado futuro
symbol_with_usdt = symbol_with_usdt.upper() # Garante que o símbolo esteja em maiúsculas
side = 'BUY' if action == 'CALL' else 'SELL'
# Ajustar a precisão do preço
stop_loss_price = round(current_price * (1 - stop_loss_percentage / 100), 2)
# Ajuste adicional para garantir que o stopPrice não acione imediatamente
if stopPrice >= price:
stopPrice = price - tick_size # Subtrair um tick para garantir uma diferença mínima
# Ajustar a precisão da quantidade
#amount = round(amount, 3)
# Obtenha o preço atual do ativo
ticker = client.futures_ticker(symbol='BTCUSDT')
current_price = float(ticker['lastPrice'])
# Calcule o preço para o trailing stop 10% acima do preço atual
stop_price_percent_above = 0.1
stop_price = current_price * (1 + stop_price_percent_above)
# Calcule o preço de ativação para o trailing stop 10% acima do preço atual
activation_price_percent_above = 0.1
activation_price = current_price * (1 + activation_price_percent_above)
# Coloca a ordem limitada com trailing stop
response = client.futures_create_order(
symbol=symbol_with_usdt,
side=side,
type='TRAILING_STOP_MARKET', # TRAILING_STOP_MARKET ou MARKET
quantity=amount,
callbackRate=0.1,
# callbackRate=0.02, # Taxa de callback para o trailing stop
stopPrice=stop_price, # Preço de stop loss
activationPrice=activation_price,
workingType='CONTRACT_PRICE',
#activatePrice=None,
priceRate=0.2 # Taxa de callback para o trailing stop (2%)
# Configuração do Stop Loss fixo
response_stop_loss = client.futures_create_order(
side=side,
type='STOP_MARKET_TRIGGER', # Ou outro tipo de ordem, dependendo do seu caso
quantity=0.01,
stopPrice=stopPrice
print(f"Ordem colocada com trailing stop: {response}")
print(f"Stop Loss configurado: {stop_loss_order}")
except Exception as e:
print(f"Erro ao colocar a ordem: {e}")
except ccxt.NetworkError as e:
print(f"Erro de rede ao conectar à API da Binance: {e}")
except ccxt.ExchangeError as e:
print(f"Erro de câmbio ao conectar à API da Binance: {e}")
except ccxt.BaseError as e:
print(f"Erro genérico ao conectar à API da Binance: {e}")
print(f"Erro ao conectar à API da Binance: {e}")
Restante do código
def main():
token = ‘####’ # Substitua pelo seu token
chat_id = -#### # Substitua pelo chat_id do seu grupo
updater = Updater(token, use_context=True)
dp = updater.dispatcher
# Adiciona o manipulador de mensagens para todas as mensagens de texto
dp.add_handler(MessageHandler(Filters.text, message_handler))
# Inicia o bot
updater.start_polling()
updater.idle()
if name == ‘main’:
main()
