Hello Binance Community,
I’ve been encountering an “Error 2015 - Invalid API-Key, IP, or Permissions for Action” while attempting to execute trades through the Binance API. Despite ensuring my API keys are correctly entered and IP restrictions are properly configured, the error persists. Here are the steps I’ve already taken:
- API Key Verification: I double-checked the API keys and regenerated new ones to ensure they are correct.
- IP Whitelisting: I confirmed that my current IP is whitelisted in the API key settings on Binance.
- Permissions Review: The API keys are set with permissions for trading, but the error suggests there might be an issue with permissions or other settings.
I would appreciate any insights or recommendations on:
- Specific API settings or permissions required for trading that might be overlooked.
- Any additional security settings that could influence API functionality.
- Recommendations for diagnostic steps or tools to trace API requests and responses.
Thank you for your help!
