Im new to python and to binance api, so far i mannaged to connect to my binance account using api_key and api_secret and retrieve the account USDT asset balance.
I would like your help writing a very simple bot.
It should check all of the USDT pairs for 24h chg% < -10% and if any of them is true then buy it for 11$ and set it for sell at 12$.
It should buy a coin only if i didnt allready bought it, need to check i dont have it allready so it wont loop buying the same pair many times…
Anyone can help me write this code please???
Thanks.
