hey guys, I’m totally new to coding stuff.
I’ve set Binance_Futures_python SDK and installed all other stuff to work on this code.
I’ve tested out post_order.py and everything seems to work.
The problem is that I want to set the program(python) to execute a stop order when the BTCUSDT Perpetual hits a certain price.
For instance, when BTCUSDT Perpetual hits $70,000, place an order to close my long position by stop-limit/stop-market at $69,999
I’m guessing that it’s a simple job but since I know nothing about coding, I can’t figure out how
There’s a very limited guide in the case of futures. I tried to use tutorials on the internet that covers with spot but I found that the endpoint(?) is very different and couldn’t figure it out.
Can you guys help me with writing the codes? or perhaps give me some guidance?
I would really appreciate your help.
