Hello
I need help
When requesting the above url, I get the message “{“code”:-1022,“msg”:“Signature for this request is not valid.”}”
Through the Binance example I confirmed that my hmac hashing algorithm works
(When you put the sample private key and query, the same encryption key as the example appears)
Please help me I can’t fix the cause
My kotlin code generate hmac
fun getHmac(message: String,key:String): String? {
try {
val hasher = Mac.getInstance(“HmacSHA256”)
hasher.init(SecretKeySpec(key.toByteArray(), “HmacSHA256”))
val hash = hasher.doFinal(message.toByteArray())
return byteToString(hash)
} catch (e: NoSuchAlgorithmException) {
e.printStackTrace()
} catch (e: InvalidKeyException) {
e.printStackTrace()
return ""
