Having LOSES with TRAILING STOP MARKET
Hello !
I’m having a lot of ORDERs with high negative ROEs!
I’m using TRAILING STOP MARKET API
It seems that it’s occurring a reversion of tendency ( long > short and contraire ) too close of order is positioned !
A lot of orders start with negative ROE and remains !
I test setting API informing ACTIVATION PRICE and without informe this ! Same results !
I’m informing PRICE ( optional ) it can creating some problem ? Delay of positioning etc
I have doubt if trailing stop is activating too !
If the order goes from status NEW to FILLED means that TS was activated ?
Tks
Yes this means that the order is triggered. Having negative ROEs means that you need to review your strategy. The endpoint is working fine.
Tks Chai … for instance !
I saw the numbers and the Entry Price of this negative orders ROE was SMALLER than ACTIVATION PRICE.(LONG) . More than one had this ocourrency!
I conclude that the Orders goes to opposite side of my choice (LONG) and than made the big negative ROE !
This make sense for you ?
And how to protect investiment when prices goes to opposite side ?
Tks
