Has testnet gone crazy ?
All my sell ordres have status EXPIRED
Is there a way to check why ?
I’m using the same ‘code’ as before the maintenance
As stated on the Spot Test Network, all data was deleted as part of the periodic reset procedure on October 2nd.
yes, but it does not make sense that I have assets that I cannot sell, the reset say that one will get fresh allowance, so if I get fresh allowance, then I should be able to buy/sell.
