gift card API clarification
Hey, first of all, I don’t really have a lot of knowledge about crypto domain, so…
I want to use the gift card API, but there is some things I wish to know.
1: Is the gitf card API the same as buying from https://www.binance.com/gift-card/create-card?
2: What are the token parameters for ( what should be in the token field )?
3: The API is for buying BTC only, right? no support for USTD, ect.
