Get error in Swagger, newOrder and bswapSwap
I’m building a proxy in NodeJs however when I use the newOrder and bswapQuote from @binance/connector I get an error code: -12015, msg: ‘Input parameter setting error’
I have used the example:
client.bswapSwap(‘USDT’, ‘BUSD’, 20)
.then(response => logger(response.data))
.catch(error => logger(error))
and when I check the response it seems correct:
/sapi/v1/bswap/swap?quoteAsset=USDT&baseAsset=BUSD&quoteQty=20&timestamp=1705320621666&signature=xxxx
Even Swagger gives an error and I can check my coins so I do have a connection, and credentials are checked.
What could be wrong?
Thank you
I don’t think BUSD/USDT is still available (can’t find it under https://www.binance.com/en/swap/pool), you can confirm this by using GET /sapi/v1/bswap/pools endpoint.
Thanks for the answear.
That’s what I thought but the example I found uses this and the error message was a bit miss leading. The team should maybe give a better error message.
Then I know for sure
The example is just an example, the time it was introduced the BUSD/USDT was probably still available, but then it was taken down.
I agree with the error message not being suitable for debugging. We’ll share the feedback. Thank you.
