I’m trying to get these data on Tradingview Chart on binance by using Binance API but I can’t found it. Could you suggest where I can find?
Thanks!
Thanks!
Hi. RSI is not provided from the API. But you can check either ticker or kline for some other useful metrics such as OHLC. https://binance-docs.github.io/apidocs/spot/en/#kline-candlestick-data
Thank you!
