Hey guys, I’m trying to generate my listenKey using the following example but I’m getting no result so far. binance-futures-connector-python/user_data.py at main · binance/binance-futures-connector-python · GitHub
I changed the following:
line 20: adding my api key & the base url= “https://api.binance.com/fapi/v1/listenKey”
line 27: stream_url=“wss://fstream.binance.com”
My IDE returns Process finished with exit code 0
Thanks in advance for the help.
