Im having trouble finding out the difference between buying a regular future (say iotausdt) and buying a perpetual (iotausdt).
I can successfully use the API to buy iotausdt regular future but want to know how to buy the perpetual iotausdt…confused.
Where are the differences? Is it the endpoint i post to or same endpoint but for perpetual i buy iotausdt_perp, for example?
Thanks so much for any help.
Graham
