Is it possible to split the user data stream listen key by symbol? docs.
Reason, I want to trade on multiple symbols using different virtual machines. However, I end up with data which I need to filter out. Which as I add more symbols becomes increasingly more wasteful.
I attempted to add symbol to both the query string and payload, however the behaviour didn’t change. Is there any other way to register a listen key / websocket stream where the it’s filtered by symbol?
