Futures API returns incorrect error code for invalid client order
I’ve noticed that the futures API returns incorrect error code in the following scenario.
The API documentation lists the following error code:
-4015 INVALID_CL_ORD_ID_LEN
Client order id is not valid.
Client order id length should be less than 32 chars
I’ve just recently made the following request:
https://fapi.binance.com/fapi/v1/order?symbol=STORJUSDT&side=BUY&type=LIMIT&timeInForce=IOC&quantity=90&newOrderRespType=RESULT&price=0.2709&newClientOrderId=TPF_6338262ce89e9cc99b92e76d4c1e9cc3&reduceOnly=true
Which had a client order id that is 36 characters long. (timestamp and signature removed)
This was working in the past month, but recently I received the following error to this:
{"msg":"Illegal characters found in parameter 'newClientOrderId'; legal range is '^[a-zA-Z0-9-_]{1,32}$'.","code":-1100}
The sent client order has acceptable characters, but is too long. I believe the error code -4015 should be returned instead of -1100.
The issue has been fixed; Please try again
This also happens when you’ve already sent an order before with the same client side ID.
