flexible rewards types
hello, I have to extract flexible rewards history, and I would like to understand better what the types BONUS, REALTIME and REWARDS means. in what do they differ? I see that BONUS seems to appear also in the dividends history? or they are just similar?
I would suggest you to look at the following two ressources:
These resources should help you better understand the different types and their significance.
