Extending Websocket connections beyond 24 hours mark
I have been suggested that if I ping the server every 15 minutes then I can extend a Websocket connection beyond 24 hours mark, is that correct?
No, ping server doesn’t guarantee that the server will not disconnect after 24-hour mark.
  • Ping server and expect a pong response from server; this communication can be used to inspect the socket connection.
  • Server could drop the connection after 24hr since the connection is initialized. So client should prepare for the disconnection.
