Expiration Reason: Exceeds the maximum allowable notional value at the current leverage.
Hi. My working neitral grid bot was expired. What wrong???
MARGIN 4к$
Each position has a maximum notional value in USDT that you can open based on the selected leverage. If you attempt to place an order that would exceed this limit, you will receive an error message. To check the leverage brackets for a specific trading pair, you can use the GET /fapi/v1/leverageBracket API endpoint.
