Error: Order's position side does not match user's setting
Q: Why do I receive the following error when I create a new order (POST /fapi/v1/order)?
    "code": -4061,
    "msg": "Order's position side does not match user's setting."
  1. Check your current Position Mode through:
  • Website:
    Screenshot 2021-09-15 at 14.45.59
  • (or) Endpoint GET /fapi/v1/positionSide/dual
  1. Compare the obtained Position Mode with what was sent in the new order’s parameter “positionSide”. The error is returned, when they don’t match!
Note:
  • “dualSidePosition” -> “true” = Hedge Mode; “false” = One-way Mode
  • “positionSide” -> Default: BOTH = One-way Mode ; LONG or SHORT for Hedge Mode. (Mandatory when Hedge Mode)
Examples of different scenarios for the error to occur:
A)
  • “dualSidePosition”: true
  • New order with no “positionSide”
B)
  • New order with with “positionSide=BOTH”
C)
  • “dualSidePosition”: false
  • New order with “positionSide=LONG” or “positionSide=SHORT”
