error code -2010 is mixed using
It seems like error code -2010 is mixed using in 2 situation. sometimes code -2010 with msg “Account has insufficient balance for requested action.”, but may also with msg “Order would immediately match and take.”
plus, search history in this site, -2010 may with more kinds of msgs
-2010 error code is associated with NEW_ORDER_REJECTED reason, which can contain several reasons, therefore the diff error messages. You can consult more on https://binance-docs.github.io/apidocs/spot/en/#21xxx-portfolio-margin-account
