Q: Why do I receive “The current currency is not open for withdrawal” when using POST /sapi/v1/capital/withdraw/apply
The full error message can look like :
{“msg”:”-4019=The current currency is not open for withdrawal”,”success”:false}
Confirm the following:
Withdraw is open for the coin and its respective network:
GET /sapi/v1/capital/config/getall -> (wanted coin) -> “networkList” -> (wanted network) -> “withdrawEnable”:true
You’re sending the correct “network”:
GET /sapi/v1/capital/config/getall -> (wanted coin) -> “networkList” -> “network”;
(This is usually the source of problem)
Withdraw address is in the same network as the sent network, if not sending network (optional parameter) use:
GET /sapi/v1/capital/config/getall -> (wanted coin) -> “networkList” -> to check the default network (isDefault": true) ;
