my websocket client (C#) keep being disconnected when I send a second command, the first one always works, the error is the 1008 Policy Violation “invalid request”.
I’ve checked the command content and it is correct, i’m using the “/stream” feed.
Do you get any error response back from the server before the close frame?
Another thing that comes to mind is frame fragmentation. Maybe that is throwing a spanner in the works. I believe, in .Net you need to set the endOfMessage flag to true in WebSocket.SendAsync() method call for it to set te FIN flag, so that the next frame is not a continuation of the previous one.
