I am trying to use websockets to control my orders. But I failed to connect on auth process.
Below is function to get the signature
def get_signature(self, private_key):
timestamp = int(time.time() * 1000)
params = {
"apiKey" : self.BINANCE_SOCKET_API_KEY,
"timestamp": timestamp
payload = '&'.join([f'{param}={value}' for param, value in sorted(params.items())])
signature = base64.b64encode(private_key.sign(payload.encode('ASCII')))
return signature.decode('ASCII')
And below is where the get_signature function call is made :
with open(self.BINANCE_SOCKET_API_KEY_PATH, 'rb') as f:
private_key = load_pem_private_key(data=f.read(),password=None)
print("private key : ", private_key)
print("self.BINANCE_SOCKET_API_KEY_PATH : ", self.BINANCE_SOCKET_API_KEY_PATH)
signature = self.get_signature(private_key)
try :
socket = await ws.connect(ENDPOINT)
login_params = {
"id": rand,
"method": "session.logon",
"params": {
"apiKey": self.BINANCE_TEST_SOCKET_API_KEY,
"signature": signature,
"timestamp": int(time.time()*1000)
} if self.is_test else {
"id": rand,
"params": {
"apiKey": self.BINANCE_SOCKET_API_KEY,
param = ujson.dumps(login_params)
try :
await socket.send(param)
auth_response = await socket.recv()
print("response from binance websocket : ", auth_response)
I got the PRIVATE_KEY.pem and PUBLIC_KEY.pem with following command on terminal.
openssl genpkey -algorithm ed25519 -out PRIVATE_KEY.pem
openssl pkey -pubout -in PRIVATE_KEY.pem -out PUBLIC_KEY.pem
What could be fixed for my problem?
