Hello, I have a question regarding using WebSocket in a .NET 6 environment to connect to Binance and retrieve contract prices. I’ve implemented a mechanism to periodically reconnect the WebSocket, but after re-establishing the connection, I’ve noticed that I’m no longer receiving the information that the WebSocket should be transmitting. Any insights or suggestions would be greatly appreciated.
public class BinanceHelper
private ClientWebSocket _webSocket = new ClientWebSocket();
private string _webSocketEndpoint = string.Empty;
private readonly string _binanceWsEndpoint = $"wss://fstream.binance.com/stream?streams=";
private System.Timers.Timer _reconnectTimer;
public BinanceHelper()
_reconnectTimer = new System.Timers.Timer(3600000);
_reconnectTimer.Elapsed += async (sender, e) => await AutoReconnectAsync();
_reconnectTimer.AutoReset = true;
public async Task ConnectAsync()
_reconnectTimer.Start();
Program.Logger.Info("開始連接WebStocket連線");
string btc = "btcusdt@aggTrade";
string eth = "ethusdt@aggTrade";
string sol = "solusdt@aggTrade";
_webSocketEndpoint = $"{_binanceWsEndpoint}{btc}/{eth}/{sol}";
await _webSocket.ConnectAsync(new Uri(_webSocketEndpoint), CancellationToken.None);
if (_webSocket.State == WebSocketState.Open)
Program.Logger.Info("WebStocket連線成功");
public async Task ReceiveMessagesAsync()
var buffer = new byte[1024 * 4];
while (_webSocket.State == WebSocketState.Open)
var result = await _webSocket.ReceiveAsync(new ArraySegment<byte>(buffer), CancellationToken.None);
if (result.MessageType == WebSocketMessageType.Text)
var response = Encoding.UTF8.GetString(buffer, 0, result.Count);
Array.Clear(buffer, 0, buffer.Length);
private async Task AutoReconnectAsync()
await _webSocket.CloseAsync(WebSocketCloseStatus.NormalClosure, "Close", CancellationToken.None);
Program.Logger.Info("每小時自動關閉WebStocket連線");
await ReconnectAsync();
public async Task ReconnectAsync()
_webSocket?.Dispose();
await ConnectAsync();
await _telegramHelper.SendWebStocketMsg("Stocket連線建立成功");
break;
Log
2024-01-10 14:28:14.0662 | INFO | Program | 每小時自動關閉WebStocket連線
2024-01-10 14:28:22.1048 | INFO | Program | 開始進行重新連接WebStocket連線流程
2024-01-10 14:29:58.6862 | INFO | Program | 釋放Stocket連線資源,重新建立執行個體
2024-01-10 14:30:09.6541 | INFO | Program | 開始連接WebStocket連線
2024-01-10 14:30:35.6748 | INFO | Program | WebStocket連線成功
