Documentation not correct for "Get C2C Trade History"
For GET /sapi/v1/c2c/orderMatch/listUserOrderHistory (Get C2C Trade History (USER_DATA))
API documentation says:
“Only the last 6 months of data can be retrieved. To view the complete P2P order history, you can download it from https://c2c.binance.com/en/fiatOrder
But when you actually go to https://c2c.binance.com/en/fiatOrder you are faced with this message:
“Selected date range cannot exceed 6 months from today.”
Any idea on how to get data older than 6 month?
If not possible using the Binance API, is it possible using any other means?
i have same issue
Thanks for the feedback, we will investigate.
any update for this issue ?
this has been long time. Any updates?
i would also like to get all my transaction records so i can file taxes
startTime and endTime is not working for this endpoint. Always return last 7 days. Please FIX it out ASAP!
