There is an action on UI to convert funds in your USD-M Futures account.
When it’s triggered, COIN_SWAP_ORDER event is received via WebSocket;
However, there it is not documented in any way. Moreover, the parameter names are not really developer-friendly - “a”, “o” etc…
Thank you for the feedback. I will pass this on to the respective team.
The property names are shortened to increase efficiency by reducing the size of the payload. However with that being said, it may be confusing to first-time users. I will also inform the team about this issue for better clarity.
It is 2024, and there is still no documentation for the COIN_SWAP_ORDER
type of FuturesUserDataUpdateEvent
. I encountered this in the web socket stream today after converting USDT to BNB through the GUI.
COIN_SWAP_ORDER appears to be at the same level as an ACCOUNT_UPDATE event, but it is difficult to reconstruct from logs just what the Event structure is.
Documentation that does exist suggests that COIN_SWAP_DEPOSIT
and COIN_SWAP_WITHDRAWAL
are ‘reasons’ for ACCOUNT_UPDATE
events, which is consistent with my logs. HOWEVER, COIN_SWAP_ORDER
does not seem to be an ACCOUNT_UPDATE
type of event.
Please document COIN_SWAP_ORDER
and related COIN_SWAP_DEPOSIT
and COIN_SWAP_WITHDRAWL
