Hi, I’m a bit confused about the difference between these two streams:
#kline-candlestick-streams
#continuous-contract-kline-candlestick-streams
Any clarification is welcome
Thanks !
Thanks !
The difference is that the first is for spot / margin and the second is for futures
your answer is wrong and confusing
Thanks! maybe the docs need some cleanup then, because even when selecting the option for USD or COIN Futures is showing the stream for #kline-candlestick-streams
The difference is in how you call the stream, one uses another <symbol>
while another uses <pair>_<contractType>
(obtain this info by querying /fapi/v1/exchangeInfo), this is to support different users’s preferences.
this is the right response. Thanks.
