Data stream calculations
Hello, I’m a complete beginner at programming. I have problem with calculations with data from Binanace stream. For example how can I calculate “high” - “low” like in line 24 in my example code?
Thanks.
import websocket, datetime, pprint, json, config
import numpy as np
client = Client(config.api_key, config.api_secret, testnet=True)
symbol = 'btcusdt'
def on_message(ws, message):
    print()
    print(str(datetime.datetime.now()) + ": ")
    #print(message)
    json_message = json.loads(message)
  # pprint.pprint(json_message)
    high = json_message['h']
    low = json_message['l']
    print(high)
    print(low)
    range = high - low
    print(range)
    if high > low:
        print("Is higher")
    else:
        print("Is not higher")
def on_error(ws, error):
    print(error)
def on_close(ws, close_msg):
    print("### closed ###" + close_msg)
def streamKline(symbol):
    websocket.enableTrace(False)
    socket = f'wss://stream.binance.com:9443/ws/{symbol}@ticker'
    ws = websocket.WebSocketApp(socket,
                                on_message=on_message,
                                on_error=on_error,
                                on_close=on_close)
    ws.run_forever()
streamKline(symbol)
  "h": "0.0025",      // High price
  "l": "0.0010",      // Low price
I think you need to convert the string to float for the calculation to work.
Thanks, its working
