data.binance.vision is not updated anymore, any other way to get historical spot trades ?
If there is any way to contact binance support for this ?
You can use this endpoint: Public API Endpoints | Binance Open Platform
Also, the upload of new files on data.binance.vision has resumed.
Your solution is not bad, meanwhile it cost some weight, not sure how much it could cost to cover a fw missing days, I will try.
Beside the spot is still lagging by 24h only the day before yesterday is now available, better, but not yet fully fixed
