Hi there,
I’m facing a problem with the Futures Coin API, when I try to read the openOrders it returns random orders already canceled or filled days before.
If at the same time I do a request on /dapi/v1/allOrders, filtering the result by the status “new”, it returns the correct list of open orders.
This is a similar problem (but not the same) of the post: /fapi/v1/openOrders randomly returns very old data
And this behavior is not related to the persistence layer (as described here:
FAQ: Error message "Order does not exist") because even after hours or days not having any activity on the account, once this behavior starts the /openOrders will always return random data.
Over the past weeks, I have been testing with different accounts and subaccounts (around 10 accounts), that never had a trade on Futures Coin before, and I’m getting always the same result.
When I start using a fresh new account, the /openOrders work fine for a few days (usually 2 days but sometimes up to 3 days) but then start to have this random data behavior.
I’m using WebSockets to control the orders when my code is running, but when I need to restart/reboot my code I check the open orders to load again to the same stage and continue to operate, and also in a few other moments to make sure that the orders were persisted on finance.
Can you guys give me help on this?
Any help is appreciated.
