Crypto Loan Assets
Hi, I want to be able to pull all data for an account pertaining to the /sapi/v1/loan/income endpoint. One of the parameters for this endpoint is asset. Does an endpoint exist which gives all available crypto assets supported for crypto loans. Iterating over all the assets (1600+) that is retrieved when calling the /api/v3/exchangeInfo is a bit unrealistic when knowing that only a handful are supported by the crypto loan endpoint.
Thanks,
Ryan Falzon
As of now, there is no endpoint to identify which coins are loanable. You may manually obtain the list via Crypto Loans | Borrow and Lend Cryptos Instantly | Binance until a more programmatic solution is available.
Thanks Alex
