Could there be a technical issue on the server?
I am sending requests using the Binance API from a Windows Server 2019 R2, but I am encountering the following error: “Timestamp for this request is outside of the recvWindow.” On Windows Server 2019, there is no “Sync Now” button, so I used the following command, but I keep getting errors. I haven’t found a different solution anywhere. Could there be a technical issue on the server?
Thank you for your help in advance.
w32tm /config /manualpeerlist:“time.windows.com,0x1” /syncfromflags:manual /reliable:YES /update
w32tm /config /update
w32tm /config /minpoll:4 /maxpoll:4
net stop w32time
net start w32time
w32tm /resync
w32tm /config /syncfromflags:manual /manualpeerlist:time.windows.com /update
The error you get when using the Binance API is “The timestamp for this request is outside of recvWindow.” This error indicates a problem with the timestamp.
Since there is no “Sync Now” button on Windows Server 2019, you need to manually set the time sync. However, this error may not be related to the Binance API, but to your server’s clock settings.
First, make sure that you have configured your server’s clock settings correctly. Then, check your server’s clock before sending your Binance API request. If your server’s clock is not correct, it may cause you to receive an API request timestamp error.
I hope this helps. Take care
check the below steps…
Update the Time Service Configuration… Open Command Prompt as an Administrator
w32tm /resync
Restart the Windows Time service
net stop w32time
net start w32time
Check Time Service Status
w32tm /query /status
w32tm /query /peers
Adjust API Timestamp Handling… Increase the recvWindow Parameter… Generate Timestamps Programmatically
import time
import hmac
import hashlib
import requests
api_key = ‘your_api_key’
api_secret = ‘your_secret_key’
Get server time
server_time_url = ‘https://api.binance.com/api/v3/time
server_time = requests.get(server_time_url).json()[‘serverTime’]
Calculate the offset
recv_window = 5000 # milliseconds
timestamp = int(time.time() * 1000) # local timestamp in milliseconds
offset = server_time - timestamp
Adjust local timestamp
params = {
‘symbol’: ‘BTCUSDT’,
‘side’: ‘BUY’,
‘type’: ‘LIMIT’,
‘timeInForce’: ‘GTC’,
‘quantity’: 0.1,
‘price’: ‘40000’,
‘recvWindow’: recv_window,
‘timestamp’: timestamp + offset
query_string = ‘&’.join([“{}={}”.format(k, v) for k, v in params.items()])
signature = hmac.new(api_secret.encode(‘utf-8’), query_string.encode(‘utf-8’), hashlib.sha256).hexdigest()
params[‘signature’] = signature
headers = {
‘X-MBX-APIKEY’: api_key
response = requests.post(‘https://api.binance.com/api/v3/order’, headers=headers, params=params)
print(response.text)
