Hello. I was wondering if you can add Convert small balances to BNB API for better data reading. Currently this API is missing and it leads to misunderstanding if we use API for reading transaction history.
Please give approximate ETA or at least tell if it’s impossible for Binance now.
You can use the Dust Transfer endpoint to convert small balances to BNB.
https://binance-docs.github.io/apidocs/spot/en/#dust-transfer-user_data
I want to read data. This endpoints allows to convert. This is not the case.
Apart from the DustLog endpoint, I’m not sure there is an endpoint related to your request.
https://binance-docs.github.io/apidocs/spot/en/#dustlog-user_data
I also found it. Thank you !
