Hola a todos/as! Queria conusltarles si alguien puede generar una consulta PHP y AJAX con varios “klines” a la vez ?¡
I will pretend to know Spanish. Getting Klines data is as simple as sending a http request
use GuzzleHttp\Client;
$client = new GuzzleHttp\Client();
$res = $client->request('GET', 'https://api.binance.com/api/v3/klines?symbol=BNBUSDT&interval=1m');
And how can I do it without using third party functions?
You will need a library helping you sending the request, maybe cURL
can help you without install package.
$url = 'https://api.binance.com/api/v3/klines?symbol=BNBUSDT&interval=1m';
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_HEADER, TRUE);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, TRUE);
$head = curl_exec($ch);
$httpCode = curl_getinfo($ch, CURLINFO_HTTP_CODE);
curl_close($ch);
I didn’t test, but similar like this. Here is the manual:
Hi!! Tnk for you!! I like your reply!
