'Connection aborted.', RemoteDisconnected('Remote end closed connection without response'
I use python future api.
When I run
res = client.get_position_risk(symbol=symbol, recvWindow=6000)
I often get error
‘Connection aborted.’, RemoteDisconnected(‘Remote end closed connection without response’
Now, I catch the error and retry.
Anyone has the same issue? How to solve it systematically?
Thank you
Are you able to get response from other methods/APIs?
How about just run
curl -v "https://fapi.binance.com/fapi/v1/time"
I am having the same issue regular RemoteDisconnected.
using client.get_historical_klines
Works find to a period a time, then errors.
Did you find a resolution?
