Coin Futures testnet api not in sync with web UI
Hi
I’m using the Coin Futures API and all works fine trough the API. But I do not see these positions/trades then on the testnet web UI. But when calling the API to get them they are all there.
Is this expected? Or should they always be in sync?
So when I do an order on the web UI I see it there but not when I do it trough the API. Then it’s only available in the API response.
Thank you very much for clarification.
Cheers
Steve
Hi.
The web UI shows USD-M futures position information by default. Please choose a COIN-M futures trading pair to view and you will be able to see the positions and trades under the chart. Please let us know if those positions or trades are still not visible for you, thanks.
Yes. This was exactly the issue. Sorry. I’ve missed that somehow.
Thanks a lot for your help!
Cheers
Steve
