I send two parameters,timestamp and signature, but get wrong message,Not all sent parameters were read; read ‘1’ parameter(s) but was sent ‘2’,it is why
Ensure that you are using the correct HTTP method e.g POST, GET
I use https, get,it is right, now I can’t connect which reply “We can’t connect to the server for this app or website at this time. There might be too much traffic or a configuration error. Try again later, or contact the app or website owner.”
“signature” should be in lower case.
yes, thank you very much
