{"code":-1002,"msg":"访问受到限制"} /sapi/v1/convert/getQuote
Hi all. When sending, the POST gives out the {“code”:-1002,“msg”:“访问受到限制”} Tell me, maybe I’m doing something wrong. End point /sapi/v1/convert/getQuote
    $header = array(
    'X-MBX-APIKEY: ' . $apiKey,
    'Content-Type: ' . 'application/x-www-form-urlencoded'
    $timestamp = time()*1000;
    $data = array(
    'fromAsset' => 'BUSD',
    'toAsset' => 'ETH',
    'toAmount' => 1,
    'timestamp' => $timestamp
    $signature =  hash_hmac('sha256', http_build_query($data), $secretKey);
    $data = $data + array('signature'=> $signature);
    $url = 'https://api.binance.com/sapi/v1/convert/getQuote';
    echo post($url,$header,$data);
As the document states, Binance API Documentation, users have to apply for this endpoint first.
There is a link in the document that you can submit the request.
Thank you! Couldn’t figure out what the problem was.
