Hei Traders,
im just getting started with API Requests, so there are still a lot of ??? around me!!
I was able to place an order with API Request. Now i want to close it.
The Documentation says, the parameters should be the symbol, either orderId or origClientOrderId and timestamp.
when i do my Delete Request, i get this Answer(see below).
https://fapi.binance.com/fapi/v1/order?symbol=ADAUSDT&orderid=11941279625×tamp=1618335360811&signature=signature
{'code': -2011, 'msg': 'Unknown order sent.'}
Pls help me, to set up correct URL.
Thanks a lot.
MJW
2
The only possible reason is it’d already filled before you sent the cancellation if your symbol/orderId are both correct
Thank you, for your advise!
How can my sellorder get filled and is still active? I dont get it.
My API call to close my existing open position, does not close the position. At the moment i have to close the position manualy.
Below you can see my POST and DELETE request to open and close a position and the data send back from binance.com.
POST https://fapi.binance.com/fapi/v1/order?symbol=ADAUSDT&side=BUY&type=MARKET&quantity=20×tamp=1618391114071&signature=[....]
{'avgPrice': '0.00000',
'clientOrderId': 'yimQ5WPFaUrDEPPOkviHSk',
'closePosition': False,
'cumQty': '0',
'cumQuote': '0',
'executedQty': '0',
'orderId': 11968320014,
'origQty': '20',
'origType': 'MARKET',
'positionSide': 'BOTH',
'price': '0',
'priceProtect': False,
'reduceOnly': False,
'side': 'BUY',
'status': 'NEW',
'stopPrice': '0',
'symbol': 'ADAUSDT',
'timeInForce': 'GTC',
'type': 'MARKET',
'updateTime': 1618391114269,
'workingType': 'CONTRACT_PRICE'}
DELETE https://fapi.binance.com/fapi/v1/order?symbol=ADAUSDT&clientOrderId=yimQ5WPFaUrDEPPOkviHSk×tamp=1618391242993&signature=[....]
I think i got it by my self.
I want to DELETE a order, but i have a open position (order got filled already).
To close a position i have to POST a sell order?! Correct?
MJW
5
Correct. What you did was order cancellation on a market order. Like I said it’s already filled before you sent cancellation
