ClientError: (400, -1021, “Timestamp for this request was 1000ms ahead of the server’s time.”
Hi team,
pleasea dvise how to resolve this as i have see github documentation, but could not find a resolution for the same, as its explained what the error means but how to resolve this time syn mismatch, i guess
thanks in advance
Sukhwant
aymens
January 17, 2022, 10:44pm
10
Can you provide us by the way with The ntp servers you’re using please ?
Thanks.
Chai
November 10, 2021, 3:26am
2
Q: Why I’m getting the error message “Timestamp for this request is outside of the recvWindow” ?
You can take a look at this thread for your issue.
how to increase recvWindow time ? any documentation on that will help
thanks
Chai
November 10, 2021, 5:15am
4
By using the recvWindow parameter in respective endpoints.
hi Chai,
sorry to ask as i am new to python. i am using below code to get wallet balances.
where to put this recvWindow parameter?
Code:
config_logging(logging, logging.DEBUG)
spot_client = Client(key, secret)
a = spot_client.account()
df = pd.json_normalize(a,“balances”)
thanks in advance
Sukhwant
Chai
November 10, 2021, 6:37am
6
Hi Chai,
i input the below and its the same error coming with max limit of recvWindow?
a = spot_client.account(recvWindow=60000)
please advise
thanks
Sukhwant
any update as this has not happned from the past 2 months. wonder why its happening now.
thanks in advance
Sukhwant
Chai
November 10, 2021, 8:07am
9
There a 2 solutions posted in the other thread.
Did you try this solution?
Adjust your local time by synchronizing it with our server time (https://binance-docs.github.io/apidocs/spot/en/#check-server-time 7). For Linux system, you can follow NTP;
