ccxt.base.errors.AuthenticationError: binance {"code":-2008,"msg":"Invalid Api-Key ID."}
I’m testing my ccxt python code on testnet binance futures.
I copy pasted the API Keys from testnet binance futures.
For some reason, I’m getting this error :
ccxt.base.errors.AuthenticationError: binance {“code”:-2008,“msg”:“Invalid Api-Key ID.”}
My API keys are hidden in another file, and I’ve double-checked them already.
I don’t see anything wrong with any of my parameters.
This is my code
import ccxt
import dontshare_config as ds
binance = ccxt.binance(
'apiKey': ds.TxP3_KEY,
'secret': ds.TxP3_SECRET,
'enableRateLimit': True,
'options': {
    'defaultType': 'future',
    'urls': {
        'api': 'https://testnet.binancefuture.com',
        'test': 'https://testnet.binancefuture.com',
Get the account balance on the testnet
balance = binance.fetch_balance()
Print the account balance
print(balance)
What could be the issue here?
I see you’re using CCXT which is a 3rd party library. You can try what was suggested in this answer in order to correctly tell CCXT to use the Testnet: python - how to tell ccxt to use binance / bybit testnet - Stack Overflow
