BVOL Binance Volatility end point
Hi there, I noticed Binance provided BVOL data but I cannot find the end point in API docs. May I know if this end point exists or need to add to wish list? Thanks.
for those want to know the data in the front end:
Unfortunately, there isn’t a specific endpoint that directly returns the Volatility Index. You’ll need to calculate it on your own based on the available data.
