On both endpoint /vapi/v1/optionInfo and /vapi/v1/exchangeInfo all assets are being shipped with zero leverage. But on your website, in the options section, it shows non-zero leverage. Should I get this information from some other endpoint?
Hi. Thanks for reporting the issue. The team is working on this part to make the field the disclose the same info as UI. Meanwhile, please ignore the 0 values.
On Website this same asset is showing with 65x leverage. I will put the print of the website in another message, because i’m a new user and I can’t put more than one image by post.
