Binance US: Illegal characters found in a parameter.
I’m trying to fetch some GET routes with Binance US API but for a huge quantity of endpoint I only have the following error as a response
{ code: -1100, msg: 'Illegal characters found in a parameter.' }
I’m using the code sample of the documentation
timestamp=`date +%s000`
api_key=<your_api_key>
secret_key=<your_secret_key>
api_url="https://api.binance.us"
signature=`echo -n "timestamp=$timestamp" | openssl dgst -sha256 -hmac $secret_key`
curl -X "GET" "$api_url/sapi/v1/fiatpayment/query/deposit/history?timestamp=$timestamp&signature=$signature" \
     -H "X-MBX-APIKEY: $api_key"
The endpoint /sapi/v1/fiatpayment/query/deposit/history does not exist.
I think this endpoint is used here (Binance.US API Documentation) right ? I’m missing something ?
My apologies the endpoint does exist on Binance.US. Can you provide the full URL generated?
Sure the URL is https://api.binance.us/sapi/v1/fiatpayment/query/deposit/history?timestamp=1661531969092&signature=<AN HEXA STRING SIGNATURE>
Obviously I do not put the signature here but the parameter is sent
I am also getting this same error when trying to get convert to BNB dust logs. Any fix for this yet?
curl -X GET "$api_url/sapi/v1/asset/query/dust-logs?startTime=$startTime&endTime=$endTime&timestamp=$timestamp&signature=$signature" \
Full URL
https://api.binance.us/sapi/v1/asset/query/dust-logs?startTime=1661775601000&endTime=1661775601000&signature=
Please feel free to join the Binance US Telegram API channel for this concern.
