This tutorial says to navigate to an environments folder in the github zip download, there are not any environments folders
Thanks for sharing this, the link is redirecting to the wrong repository, the correct one is: https://github.com/binance/binance-api-postman
And the file you’re looking for after the download is: https://github.com/binance/binance-api-postman/blob/master/environments/spot/binance_com_spot_testnet_api.postman_environment.json
