I am trying to test a bot on the Spot Test Network but when I try to do acc = client.get_account()
to access some account info that is needed it raises the following error APIError(code=-2015): Invalid API-key, IP, or permissions for action.
I have tried finding a solution but can’t find anything besides a step i dindn’t do from the tutorial on the Binance Spot Test Network
the step says:
Follow the official Spot API Key documentation to replace the API endpoint URLs with the following values:
https://api.binance.com/api → https://testnet.binance.vision/api
wss://stream.binance.com:9443/ws → wss://testnet.binance.vision/ws
wss://stream.binance.com:9443/stream → wss://testnet.binance.vision/stream
When I look in the documentation I cant find anything that would help with this problem. I am not sure this is the solution but it is the only thing I could find on it.
