Hi all - using the new Binance Mirror functionality, how can you access the “transfer” (mirror) into your spot account via the API?
Example - if I mirror 1k from Binance Custody into Spot - where does that appear on the Spot API?
Hi, can you give more details of what exactly is this Mirror function?
thanks
