I have an issue with placing LIMIT order in binance futures. Please consider the following inputs.
def rounded_qty(qty, step_size):
return round_step_size(qty, step_size)
def get_step_size(sym):
info = client.get_symbol_info(sym)["filters"]
for filter in info:
if filter["filterType"] == "LOT_SIZE":
return float(filter["stepSize"])
def usdt_to_btc(usdt_qty):
base_qty = float(usdt_qty) / float(client.get_symbol_ticker(symbol="BTCUSDT")["price"])
step_size = get_step_size("BTCUSDT")
return rounded_qty(base_qty, step_size)
symbol = "BTCUSDT"
usdt_qty = 120
btc_qty = usdt_to_btc(usdt_qty)
usdt_to_btc()
converts USDT into BTC with LOT_SIZE filter. As binance api returns 0.00001 as LOT_SIZE (stepSize) for BTCUSDT and on the basis of the LOT_SIZE my btc_qty value is 0.00277 wit current rate of BTCUSDT.
So as per binance futures requirement I have btc quantity which is already converted in given lot_size and I place limit order with price and btc_qty which is 0.00277 but it will get error
“binance.exceptions.BinanceAPIException: APIError(code=-1111): Precision is over the maximum defined for this asset”
but when I pass quantity 0.002 (LOT_SIZE - 0.001) instead of 0.00277 (LOT_SIZE - 0.00001) it will executed without error.
Why?
