Is it possible to get regular Binance data while using the BinanceUS API? As in it gives the price data, volume, etc. from Binance and not BinanceUS but through the BinanceUS API? I guess I should also add that I am just looking for price data and dont need the ability to execute trades etc, so it could be from a public endpoint like the /klines one.
You seem to only want market data, which mostly allows public access and doesn’t require a an account: Binance API Documentation
For other non public endpoints on Binance.com, you can’t access with a Binance US account.
When I try to access something like “https://api.binance.com/api/v3/klines?symbol=ETHUSDT&interval=1m” I get error 451, despite it being a public API endpoint that does not require an API key.
US regions can access the binance.com API either.
You can consult the “b. Eligibility” section on https://www.binance.com/en/terms
